Brief Description: Brackets riveted to aft ribs (14-3)
Brackets riveted to aft ribs (14-3) I riveted for both the left and right wing ribs the flap support brackets and torque tube brackets to the Aft ribs. For the flap brackets, I used the c-frame to back rivet the 470 round head rivets. I was able to squeeze the rivet around the bearings, but the rivets to the rib web on the angle pieces required bucking.
Flap bracket riveted in place on most inboard rib (23-107)
Torque tube brackets also riveted in place (23-108)
