Brief Description: Prime and attach tie downs (13-5)
Primed tie downs and attached nut plates, then attached them to the spar. These had to be bucked, but it was fairly easy with the plastic shield/cover over the round head rivet set. The rest of the attachments were bolts through the aileron bellcrank support brackets. This complete section 13.
Primed and nut plates attached (23-080)
Tie down riveted to spar (23-082)
Aileron bellcrank support brackets bolted on (23-085)
