Brief Description: Wing construction begins (13-1)
I finished riveting the wing spar extensions. The squeezer worked on some of the rivets but using the c-frame and back riveting the rivets worked best. I started on the J-channel stiffeners, but got a little confused in the instructions, so wanted to do a little more research before I mess anything up. I cut them to size, but I haven’t drilled anything yet. The instructions only talk about the left wing, so I am assuming all the same stuff applies to the right wing, but there’s no instruction stating that (like in section 14, where it states instructions are for the left wing, and the right wing is just a mirror image).
