Brief Description: Rivet bell crank and battery tray (10-17)
Riveted the bellcrank assembly together. It helps to get everything centered with a couple rivets, then cleco the remaining holes to clamp it together. If you put the clecos in first, then the rivets may not go in easily. Clecos have allow a little movement. Also set the nut plates on the battery tray. I was able to get to everything with the squeezer…used either the regular yoke of longeron yoke.
