Primed the elevator skins. For the end cap skins I tried to mostly get the inside and hits the outsides on the ends. I figure once everything is together, I should be able to remove most to the overspray. It will all get sanded and clean prior to paint anyway. I didn’t have enough room on the table to do all the components at once, so I broke it up into 2 sessions (left and right-side elevator parts). This way there is last chance of mixing up parts…even though everything is marked.
Priming parts for elevator (22-054)
More parts primed (22-055)
Inside skin primed except for masked locations for foam ribs (22-056)
