Well it’s been over a month since I had some time to work on the -10. With end of the year pressures at work, the plethora of Service Bulletin’s on the RV-12, and the condition inspection, I’ve had no extra time. I’m still waiting to do the prop balance on the -12, so I thought I would spend some time this weekend cleaning up the shop (aka garage) and deburr some parts for the rudder. It’s not too bad when you combine a little football watching while deburring…also helps if the wife is out of town and doesn’t see you deburring in the living room. Working on the countersinks, then I need to read up some on the best technique to do the trailing edge.
