Marks Web Site
Date:  12-18-2023
Number of Hours:  6.00
Manual Reference:  16-2
Brief Description:  Top skins (16-2)
Final drilled the left-wing top skin and countersunk the holes for the wing walk area. Unfortunately, I wasn’t paying enough attention when I drilled the holes for the wings walk doubler (W-1027B) and I had it flipped around. I think it will work, but I went ahead and ordered another one. We’ll see how long it take s before I get it with all the re-org happenings at Vans. Since they are identical, I used the other one for the left wing and continued building. I countersunk the screw holes for a #8 screw, which cuts into the thickness of the doubler, so now it’s a match for the left wing only. I also sanded down the corners of the top skins where they overlap next to the tank skin, so it doesn’t stick up quite as bad. I sanded it down as much as I felt comfortable with. Now I’m ready to start dimpling, priming, and riveting.
Countersunk holes for number 8 screws (23-182)
Wing walk area countersunk (23-183)
Overlap corner shaved down (23-184)
