MARK'S WEB SITE
Date:  1-14-2023
Number of Hours:  3.00
Manual Reference:  Section 9-10
Brief Description:  Canopy Frame Fitting
I decided to make some bend templates from picture frame backer board. I cut a rectangle piece 10" wide and 30" long. I laid the template on the canopy deck of the fuselage and drew the profile. I flipped it over and did the same thing on the left side. I then razor cut the lines I had drawn and now I had the left and right slider frame templates. I cut 3 blocks of wood from a 4 X 4 and drilled 2 7/16" holes that would be the center block. I matched drilled the block to my wood working bench and blocked the block to the bench. I wrapped the lower canopy frame rail with tape and placed the frame into the jig. Used a large c-clamp I applied pressure to the center of the frame rail beyond the arc I needed due to the springback quality of chrome-moly. I left it clamped for an hour and then checked against the template and repeated until the canopy rail matched the template. I repeated the process for the other side. DWG 43, section F-F shows the canopy frame rail inset about 1/16" from the fuselage sides. Next will be the bending of the aft and forward frame bows to match the top of the fuselage and roll hoop profiles.
Canopy Frame Bend Templates
Bending Jig
Bending Jig
Bending Frame Rail
Bending Frame Rail
