I had already fit and primed and painted the F-750-L&R aft baggage side covers in November, but I wanted to find a cleaner hold down instead of the steel eye bolt. What I found were aluminum quick disconnect tie down rings that can be stowed when not in use. I fit and bolted the tie down anchors to the side covers with the supplied hardware. I riveted the side covers to the fusalage with LP4-3 rivets and K1000-08 nutplates as called for in DWG 29.
