Marks Sling Project
Date:  2-9-2012
Number of Hours:  5.00
Brief Description:  Inspection
Prepared for inspection,
Wet & dry paper on skins - might give the painting a go myself?? still undecided.
Garreth came from the Airplane company for an inspection before closing up skins.
He was very complimentary about my build! Go Garreth!!
A couple of rivets needed redoing.
The wire supplied with the strobe is 1 wire shy ! will have to use the shielding as a wire
Supports at rear spar are different - there are some notches to help with identification
There are a few drilled holes at the bellcrank inspection = ?? no idea what they are for.
Wiring for Strobe
Wiring for Strobe
Rear  skin supports
Rear skin supports
Mystery holes
Mystery holes
