Marks Sling Project
Date:  6-5-2012
Number of Hours:  6.00
Brief Description:  fixes after inspection
Redo wheel assembly
Notch for brake caliper cleared slides freely. Had a moment getting them off - I had used locktite on the bolts holding the disks on - thought I was going to shear or strip the hex - phew.
Soundproofing completed and grommets for antenna cable fitted. I wont be able to get the front skins without removing the rudder pedals.
Rivet the front firewall and measure / cut the soundproof/silver foam for same
