Marks RV8 Web Site
Date:  4-28-2018
Number of Hours:  4.00
Manual Reference:  N/A
Brief Description:  Pitot Tube Mast
Drilled a hole for the pitot tube mast. Started by using a uni-bit to drill two large holes. Then used a dremel tool with a stone grinder to shape the hole. Finally used a scotch-brite wheel to polish the hole. After fitting the tube through the hole, clamped everything into place and drilled the holes for the rivets to hold the mast in place. The holes along the spar aren't countersunk, The ones near the back of the mounting plate will be countersunk and the holes in the skin will be dimpled.
Template in Place
Template in Place
After fitting tube
After fitting tube
Drilled the mast holes
