Marks RV8 Web Site
Date:  3-23-2017
Number of Hours:  3.00
Manual Reference:  7-12
Brief Description:  Aileron Pushrods
Got the new parts for the pushrods.
New blade for the tubing cutter, got everything cut to length. Had a very hard time getting the threaded rod ends inserted. Had to file the rods to get them to fit.
Drilled the rivet holes, cleaned, deburred. Inserted each rivet, then cut off the very ti end of the rivet with a dremel tool. Used the grinder with the scotch brite wheel to polish the head. Then squeezed them very slowly. Worked this time with no deformed rivets.
Oiled the interior of the tubes with LPS-2 oil before the last rivet.
Cut to length
Cut to length
Shaving -12 Rivet
Shaving -12 Rivet
Squeezed
Squeezed
