Marks RV8 Web Site
Date:  12-2-2013
Manual Reference:  7-9
Brief Description:  Spars & Conduit
Drilled spar for the skin dimples.
Pulled the conduit throught the rib holes. I was at a loss on how to do it and after reading a bunch of posts on VAF, decided just to "muscle it though" as recommended. Started at the outboard of the wing. I found that keeping the tubing under tension from both sides helped to elongate it and make it a little easier to pull through.
Conduit in place
Conduit in place
Countersink
Countersink
Spar
Spar
