Marks RV8 Web Site
Date:  2-9-2013
Number of Hours:  3.00
Manual Reference:  7-2
Brief Description:  Tie down plates
I drilled out the tie down plates and spacers. They looked like shidoobee. I ordered two new plates and some aluminum bar to start over again.
Biggest problem I had was with drilling. I had set everything up for super high speed drilling since I read that was best for aluminum as opposed to steel where slow is better. Problem is that the drills wander all over the place at 3000 RPM. So I slowed everything down to about 800 RPM to start the holes, only speeding up to 1800 when the hole is formed and the bit centered.
At any rate, will toss these and start over.
Finished plate
Finished plate
Tie down plate bolted for drilling
