Marks RV8 Web Site
Date:  1-27-2013
Number of Hours:  3.00
Manual Reference:  7-2
Brief Description:  Wing nut plates and tie down attachment
Countersunk rivets and attaching plate nuts to the spar.
Also tapped out the 3/8 x16 screw threads in the tie down plates. These proved to be really difficult as I had a pretty cheap handle. Won't use it again. Also make sure to use plenty of oil and Boe-Lube to ease the cutting. They worked out perfectly.
Made 4 spacers out of aluminum bar to fit behind the tie down plate.
This time I took a while to read all the steps, look at all the drawings, and get everything laid out before starting. Its really not like the elevators A, B, C directions. But taking the time makes everything pretty clear and straightforward.
Tapped tie down plates
