Marks RV8 Web Site
Date:  6-18-2023
Number of Hours:  3.50
Manual Reference:  8-54
Brief Description:  Attach HS
Leveled the fusleage sie to side and front to back. Attached the HS and centered and leveled. Drilled the holes in the HS spar to attach brakets. Had a harder time doing the front spar flange to desk holes but was able to reach them with a 12" drill bit. Used AN470-4-12 rivets I had to hold things into place. Then one by one drilled out the rivets and drilled #12 and replaced them with the appropriate bolts.
Will work on the vertical stab tomorrow. The heat index is 110-120 so I can work for about three hours in the AM before I have to quit.
Centered and level
Centered and level
Leveled at the back
Leveled at the back
Attached.
Attached.
