Marks RV8 Web Site
Date:  5-31-2021
Number of Hours:  1.50
Manual Reference:  8-34
Brief Description:  Fuel line
Wish I'd known this before. The tubing comes in a roll. I unroll it and cut it to length but it is all wavey. Solution is to straighten it roughly by hand and then use a 2x4 or board to roll the tubing over a flat surface. The result is as straight as you can get it without special tools.
Made the fuel line from the right tank to the fuel pump area. I am going to use a different fuel valve and the fuel injected engine so I ordered all that from Van's so I can finish the fuel lines before I rivet the front skins.
Before
Before
2x4 & workbench
2x4 & workbench
After
After
