Marks RV8 Web Site
Date:  7-10-2020
Number of Hours:  1.00
Brief Description:  Electric Aileron Trim
Drilled the mounts for the electric aileron trim and guide tube. Took a while to figure out as the kit has changed a lot from when the instructions were written. The spring holders are already welded to the control tubes instead of coming flat and being riveted to it. The holes for the brackets are already there and the holes for the tubing are pre-cut.
Primed with nutplates attached
Riveted in place
Riveted in place
