Fitted and drilled the lower left longeron. Clamped in place, had to pull it out twice to adjust the bends but it fit amazingly well given I was wailing on it with a hammer two weeks ago.
Once clamped, drilled the aft most hole, cleco'ed, drilled the four front bolt holes, installed temporary screws and then match drilled.
