Marks RV8 Web Site
Date:  5-10-2014
Number of Hours:  3.00
Brief Description:  Cleanup and holes
spent several hours removing cobwebs from the garage.
Removed the sender/float from the left tank which has the flop tube then cut a hole around the sender hole. Will use the original plate for the wing root to close the hole and mount the fuel sender.
