Marks RV8 Web Site
Date:  6-25-2023
Number of Hours:  3.00
Manual Reference:  8-55
Brief Description:  Vertical Stabilizer
Centered the VS vertically and horizontally. Measured out all the bolt holes, marked and drilled. Aligned the VS then drilled out the front spar and spacers. Temporarily bolted all the fittings into place.
Left two holes undrilled in the VS front spar and spacer where I couldn't get the angle drill in easily. I will drill those after removing the rudder.
Measured
Measured
Temporary bolts
Temporary bolts
All bolts and clecos in place.
