Trying to figure how I can do the rivets since I cannot access the heads. I decided to use a piece of flat steel which I normally use for back riveting. I put it in place on top of the rivets and then cut/sanded a block of wood to fit under the skin to hold the bucking bar in place. I repeated the exercise for the two rivets at the back of the gear box assembly.
