Started by drilliing the 7/16" holes in the fuselage. Almost broke my wrist as the bit caught in the steel and I had the drill set without torque.
Drilled the main landing gear 7/16" bolt holes using a drill press. The manual recommends using Boelube but I find that kerosene works much better as a lubricant for drilling steel.
