Got the new tubing so I cut and bent the fuel line for the right tank. I used some scrap to model the bends and it worked first time!
I then cleco'ed the front skins into place. I am not going to rivet them at this time as I want to preserve access for installing the firewall fittings, the brakes/rudder pedals and the control rods. Cleco'ed all the gussets and longerons.
After that I removed the baggage compartment floor and wall. I also removed and fixed up the brake lines which had been my first lines.
Going to ballast the front tomorrow and start to install the bulkheads and tail cone.
