Finished all the assembly of the forward fuselage parts. Marcey, Luke and I moved it out of the way. I moved all the remaining parts from the box into either bags or bins and stored it in the forward section or around the garage.
Started the rear tailcone section. Separated the F-800 parts into all the angles, polished, deburred, cleaned and fitted.
Prepared the F-812 bulkhead, and fitted the tail spring mount. Drilled all the parts and then primed the WD-409 tail mount.
