Marks RV8 Web Site
Date:  11-8-2014
Number of Hours:  3.00
Brief Description:  Fuel Tanks - Sealing
Last try to seal all the rivets on the fuel tanks. Mixed up the Pro-seal, thinned it a little with Xylene and re-riveted all the drilled out rivets. Also sealed the back of the rivets.
I have some Green Loctite which I may use to do one or two little leaks but if this doesn't work, I am going to re-order all the tank hardware and start over.
