Brief Description: Added 10 gal of 100 LL to fuel tanks.
Connected fuel lines from tank to fuel gauges using blue fuel line purchased from aircraft spruce. Added ten gallons of 100LL to fuel tanks and checked fuel system for leaks. Found minor leaks and corrected them. Fuel in fuel gauges with plane in ground attitude is 3/8" under last mark. After checking fuel system I rolled the plane out side the hanger and fired up the engine. I did not have engine readings so the rest of the day was working with the GRT EIS and EFIS to set up all the info. At first I had no tachometer then I remembered I had not put the fuse in the inline fuse holder yet. Now it is up and running. Will play more with it as I get all the setting done. Started the ELT install and I'm placing it under the right seat.The engine runs great and is very smooth
