Worked on pattern for cowling using poster board I laid out the cowling pattern and will transfer it to the full sheet of .025 aluminum on Saturday and set in place. I made a poster board pattern for top of cowling that will open to give access to the battery, air filter, and Firewall electrical. Made pattern for one side then turned over to check other side and it was a perfect match. It sure makes me feel good about that as that means the cowling is centered as it should be.
