BushCaddy ELSA
Date:  10-21-2008
Manual Reference:  Engine Manual
Brief Description:  CHT probes and throtlte cable install
Removed spark plug on exhaust side of each head and removed a small amount of aluminum cooling fin above spark plug hole. Removed gasket from spark plug and installed CHT probe then re-installed spark plug gasket. Installed throttle linkage that I purchased from Jabiru Pacific for my application of double control to one carb. I drilled the Bushcaddy throttle control rod at 1 inch from center of control rod for cable attachment. I had to run the firewall fitting back wards to leave room for the cable end. For a great description of installing the CHT probes see Ron Shannon’s web site, he is building a Murphy Rebel with the Jabiru engine.
Ron's web site www.n254mr.com/blog
