BushCaddy ELSA
Date:  5-10-2008
Number of Hours:  3.00
Manual Reference:  None
Brief Description:  Worked on Cowling and oil coler
Fit up Jabiru cowling. I had tried the nose bowl that came with the kit but it would take more work to get it fit up right so I looked at two different Jabiru nose bowls and decided on this one from the J-250 airplane. One nice thing is it is already set up for air to the oil cooler. Now I will continue with the engine and set the engine components in place first then work on the rest of the cowling. I mounted up the oil cooler and have it all ready as per the Jabiru engine installation CD from www.homebuildHELP.com I will be adding some vibration damping mounts from McMaster Car part number 9376K11 when they arrive.
J-250 nose bowl
J-250 nose bowl
