Brief Description: Installed engine mount for fwf setup
I finally made it back home after traveling for work and the Holiday. I laid out the FWF for the engine mount bolt pattern and drilled the holes for the AN5-26 bolts using three different size drill bits. Mounted the engine mount on the bolts and started planning the lay out of the heat box, cabin heat box battery box and other components. I will be working more on it next week setting the engine to finish the lay out of the FWF components but Elk hunting is calling this week end.
