Installed Transponder antenna, Installed parking break valve on F/W with two bolts and metal lock nuts (awaiting some small parts that I had to order to finish that). Installed Jabiru supplied voltage regulator and started wiring. Need to run the yellow wire to the power buss bar when it arrives. Installed starter solenoid on F/W with two nut plates and screws and wired to battery. I just want to tell every one if you are doing you own wiring and need connectors and wire purchase them through www.steinair.com they have been great and are fast in sending things out. Good prices to. Don Morrisey turned me on to them.
