BushCaddy ELSA
Date:  4-3-2009
Manual Reference:  Matco Manual
Brief Description:  Brakes and 12 volt outlet
Ran both break lines from F/W down to gear legs and attached to Matco brakes. I am using the 1/8” nylon tubing from Matco and it is a great product and is very easy to use. The fittings are easy to use you just run the tubing through the nut and into the fitting then tighten and you’re done. I ran power from the AUX 1 switch on my switches to the 12 volt outlet. Took some time to plan my intercom and head set wiring. Now time to play with the grandkids they are visiting today.
