BushCaddy ELSA
Date:  3-8-2009
Number of Hours:  2.50
Manual Reference:  None
Brief Description:  Engine throttle cable
Well it has been to long since I have worked on the plane. Today I was able to work on it and start to get back into it. Seam when you have to leave it for a while you have to figure out where you left off. Today I installed the throttle cable, Carb heat cable and cabin heat cable through the firewall. I decided to go with a single throttle cable on the left side instead of the dual throttles.
