BushCaddy ELSA
Date:  3-27-2007
Number of Hours:  4.50
Manual Reference:  Section F
Brief Description:  Finished cabin roof
Cut 100 mm holes in top of fuselage for aileron adjustment. Cut smoked polycarbonate for skylight and installed. Laid out drilled rivet holes, deburred rivet holes and dimpled outside rivet holes on cabin. Primed cabin roof and cabin frames. Riveted cabin roof using 412 for the cabin edges and 410 rivets in the center line livening the front and back clecoed for additions latter. Move the cabin and fuselage together and clamped after lifting the tail and placing a couple of boards under it. Everything lined up perfectly did not have to take anything apart or make adjustment of any kind. Thanks Don from the start you said to make sure and use a jig to set up bulkhead number one and clamp it there and I did and it worked. I have an A&P coming for dinner tomorrow to check on my work so now I will stop for now and clean up.
