BushCaddy ELSA
Date:  3-25-2007
Number of Hours:  5.00
Manual Reference:  Section F
Brief Description:  Workd on cabin skin and glare shield
First thing this morning deburred and primed both front cabin skins and glare shield. Trimmed glare shield to marks I had made when it was in place. Used edging tool to roll the edge on side skin were skin sill overlap bottom and glare shield were it overlaps side skin. Clecoed glare shield in place and laid out rivet line for glare shield to panel, drilled using the rivet gauge. Man does that make things go fast and more accurate. Removed and deburred the new holes. Dimpled door edges, front rivet line and window rivet line on side skins. Dimpled glare shield for were window will be. Clecoed front skins PF-221 to cabin sides and clecoed glare shield in place.
