Brief Description: Worked on cabin top and Primed bottom panels
Drilled PF-182 for front of cabin, deburred, primed and riveted to PF-190 & PF-191. Only cleco to cabin frame as you will remove top while working on bottom. Clamped top skin PF-219 to top frame and marked from under side frames and skylight and removed. Drawings label the top skin as PF-182 but the true part number is PF-219. Turn cabin over to start bottom work. Cleaned, roughed surface with green pad and primed all the bottom skins and frames.
