BushCaddy ELSA
Date:  3-6-2007
Number of Hours:  4.50
Manual Reference:  Section F
Brief Description:  Left cabin side and ASS-001
I had to stop by Wicks to pick up some more 426-4-6 rivets as the kit only had 150 and I used 135 last night for the right side. After talking to Don via email he has not found a place to use the 425-4-5 yet and has only used the 426-4-6 were it calls for 426-4-5. Sure is nice to have Wicks right at the airport for the little things. Counter sunk rivet holes before clecoing the parts together. I used the squeeze riveter for the first time. It sure makes it easy to set rivets but will build up mussel you did not know you had. Left frame is now completed. Installed part PF-192 on both sides. The way the drawing is illustrated on A-C-010 it looks like there are two PF-192 on each side but there is only one for each side and they go were shown on A-C-011 The hole is not for the bolt it is for the cable and should face in and you drill trough the blank side. I constructed ASS-001 as per drawings A-C-012. I inset the AN3-7A bolts 25mm as I did not find any measurements for them and extended part PF_143 out 75mm from end of PF-133 and PF-144. That is 40mm as per drawing A-C-013 and 25mm for the width of the angle frame. Cleaned and primed all parts.
Left cabin frame
Left cabin frame
270 driven rivets so far
ASS-001
ASS-001
