I laid out rivet lines for left wing top skin. Drilled from center of wing out to the tip at the stringer to rib connections and clecoed then out to the root of the wing. Now I am set to drill the rest of the rivet holes tomorrow. Set fuel tank in place to lay out the screw holes.
