BushCaddy ELSA
Date:  6-26-2007
Manual Reference:  Sec K R-120 & R80
Brief Description:  Started rib for left wing
Laid out front and aft spars and squared, clamped in place. Started laying out ribs cut U-14 for ribs 11 & 12 drilled, deburred and riveted them on ribs. Drilled, deburred and riveted 351T & B on rib 6. Drilled and clecoed ribs 1, 11 & 12. The lay out of the ribs using the two different set of drawings you have to watch were the measurements are taken. Rick is having the drawing updated and should be fix for the next one. The R-120 drawings measure from the root of the wing to the root side of the rib and the R-80 measures from the root of the rib to the wing tip side of the rib from the rib 1-6 and 12 are all at the same mark. The reason for the use of two drawing sets is I am installing the larger fuel tank then normally comes with the kit. The only rib that is out of place compared to the R-80 drawing is rib 11 and that measurement comes form the R-120 drawings. That is where you need to remember that the measurement is taken from the root end of the rib to the root side of the rib.
