Deburred cleaned and primed trailing edge skin and riveted in place. Fit fiberglass wing tip to wing.
Note: I purchased two Sharpie Professional markers to use to lay out rivet and cut lines, they worked well with the exception they do not remove easy when you try to clean it off with MEK. I recommend you not use these Sharpies. Use the standard sharpies as they are easy to clean with MEK. I will give these to the wife to use as I have cleaned her house out of them when I started this project. You can never have enough of them and the tips wear out fast that is why I tried the Professional ones.
