Ran two 16ga wire and two 18ga wires for navigation lights. I used the vacuum to suck a small line through the tubing and pulled the wire through with it and left a piece of line in the tubing if I ever need to pull more wires or change one. Completed the drilling of rivets holes on nose skin. Drilled bottom of trailing edge rivet line.
