Placed top skin in place and cut out for Aileron and trimmed wing tip. I used the electric metal shears that Don talks about in his log. They are great picked it up in Bellingham WA at Grizzly. I laid out rivet line doing a lot of measuring and checking before making the first cut or rivet hole. Then it was off to the races and holes galore. Rivets are spaced 32mm on the stringers and 64mm on the ribs. Had to take some clecos from the door panel to get this far. Have all the stringers drilled and two ribs will continue tomorrow.
