Deburred and dimpled stringers to ribs rivet holes and riveted in place with 412 rivets. (Some of the following was copied from Don's Log) "The OD of the tube is 1/2" and the ID is .370. K329 needs to be inserted in the end of the push tube, this has the female thread that will accept the MM 4 bearing. K 329 has an OD of .375" so I used the "3/8 bit to bore it out to a depth of 75 MM, which is the length of K 329." I inserted K 329 and drilled two holes through the tube which will be held in place with 2, CCP-48 stainless rivets (1/2" grip). I didn't have these in my kit but thanks to Don he sent them to me when he sent me the large grommets. He found them at the Sonex website. Take into account the length of the threads (25 MM) on the MM4 bearing when planning the holes. The MM 4 bearing will also get a jam nut on final installation. I installed the UHMW PK-314 with two AN3-A bolts and two washers on each bolt with a Nylock nut. A AN3-6A bolt would have worked better as you would not need two washers. Placed the top skin in place and wil start there tomorrow.
