Placed 13mm spacer under trailing edge at wing tip to set the wing washout. Do not install any U stringers on the nose ribs at this time. The new drawings will state this when they come out. I will be using one u stringer on the nose rib to hold them in place but will not be riveting to it. You only rivet the nose skin to the nose ribs and spar. In building this plane I am using the R-80 wing drawing somewhat but manly the R-120 because I am installing the larger fuel tank (18 US Gal) but no flaps. Used the laser level to check the trailing edge ribs for the 19mm setting. I also supported the aft spar in different places to maintain the washout. Rib 12 is clamped at both ends to keep it flat along with the front spar along its length. Completed U stringers on wing top and trailing edge.
