Riveted the front and aft right wing spars using 470-4-5 rivets. Drawing calls for 470-4-6 but they are to long. Bolted on parts to keep them together on the self while I set up the left wing spars and rivet them. Only torque the parts that would not need to me removed. Had my first solid rivet that I had to drill out and missed the hole so had to put in a 470-5-5 rivet. After talking to Rick I had to cut the backing plate PK 326 off by 15mm as it would be under rib number 5. The top bolt for PK-307 will be in the rib. I will have to notch the nose rib when I install it. All this has been cleared with RIck.
