BushCaddy ELSA
Date:  2-21-2007
Number of Hours:  6.00
Manual Reference:  Section D
Brief Description:  Continued working on horizontal stablizer
Turned fuselage over, primed bottom skin, laid out rivet line on right bottom skin for horizontal stabilizer and leading edge, debured, riveted bottome and leading edge. Debured and riveted aft left side skin. Using a welding rod to check the notched I made in the vertical stringer on right side next to inspection cover for rudder cable clearence.
Notch for rudder cable
