Primed skin cornners A-011 on the inside with primer. Installed lower inside corners A-010 and riveted in place. Make sure to make your cuts at each bulkhead and bend the tab out to rivet to the bulkhead. Over lap at the front should be a couple of inches over hang to allow for the removalbe cornner to be attached and give good suport. It will be attached with screws. Bottom corners are attached with five 410 rivets and conection joints are at bulhead 2 and 4. The top corners conection joints will be at bulkhead 3 and 5. Make a line down the center of the bulkhead cornners and drill your first hole in the center of the cornner were the bulkhead is then looking through the hole line up the mark and drill. Cleco and line up the next hole. Then drill all the rivet holes and cleco in place as you move down the cornner
