After talking with Mike from Bushcaddy he told me about setting the limit on the Ailerons with stops on PF 196 using angle aluminum. The control surfaces have limits on the travel and are as follows.
BushCaddy control deflection Elevator up 16 deg, down 13 deg Aileron up 25, down 19 Rudder 25deg Left & right Flaps 30 deg down
Mike Boisvert Cdn. Light Aircraft Sales & Service tel: 450-455-2773
I have already set the deflection on the elevators and rudder and you can view them in prior posts.
